Introduction: 15 Minute Teriyaki Chicken
What you need:
Chicken
Teriyaki Sauce
Water
Pan
Range
Utensils
Warning:
Don’t burn yourself. Wash everything when you’re done. Cook meat thoroughly.
Step 1: Wash and Trim
Wash your chicken! Then trim it chicken. I’m a bit obsessive about it and trim all the fat off.
Step 2: Cut
Cut the chicken into small strips or nuggets. It’s easier to eat, cooks faster and absorbs more sauce
Step 3: Cook!
Place pan on burner and set to medium-high. Add chicken. Cook the chicken until it browns on the outside. Be sure to rotate it so it cooks evenly and completely. Cut a larger piece in half to check when you think it’s done. It should only take around 7 minutes.
If you’re burning the chicken turn the heat down.
Step 4: Marinade
Reduce heat. Add a bit of water. This will cool the pan, keep the chicken from drying out and thin out the sauce. Go easy on the water.
Add teriyaki sauce! Put enough in so meat is covered about ¼ to ½ the way up. Stir it around.
Step 5: Serve
Turn off the heat and serve it over rice!
