Introduction: 3 Ply Wood Cruiser Board Simple
Step 1: Get Wood
Get either jigsaw or hack saw or both (recommended) and get a belt sander it orbital sander. Next you need to get some glue preferably tite bond 1,2,or3. Now all you need is wood I have used wood from a construction site and better yet 1/8 inch lite ply from Midwest products in a 12/24 inch piece. Oh and you also need a drill for the truck holes
Step 2: Make a Press
Watch these videos to get an idea of how to make whatever style press you want mine was pretty thrown together. These are pretty simple to make and to come up with your own design.
http://m.youtube.com/watch?v=-fV7Rh6-uiw
http://m.youtube.com/watch?v=D6fXIKzFY_M
Step 3: Cut It Out
Now your ready to use your jig and hack saw so get cutting and the. Start sanding the edges, I recommend you take a short length of PVC pipe and cut it in half longways the. Take a piece of sandpaper and put it in the tube. This will make a slightly rounded rail and make your board look way more professional. You will also need to drill the holes at this point, you can do it after stain and clear coat if you want but it is not recommended. Here is a link to a truck hole template, the new school pattern is off so only use the old school one for this template.
chrome://external-file/r2template.pdf
Step 4: Stain
Now you will need to get some stain in whatever stain/color you want and sand your board to perfection. NO MORE SANDING PAST THIS POINT
You will need one or two costs of stain then about the same amount of coats of clear coat or polyurethane.
Teach It! Contest Sponsored by Dremel
Great Outdoors Contest
