Introduction: 3D Printed 1:10 OpenRC Formula 1 Car
About: Award-winning Swedish 3D designer and 3D Printing evangelist. Author of The OpenR/C Project and The OpenRailway Project.
This is the OpenR/C Formula 1 car. It´s the third generation 3D printed OpenR/C car and this time around focus is on simplicity! You can print everything in PLA except the tires which are done in NinjaFlex! Of course you can print it in any material you like but for those that want to print a car but only have PLA at hand, this is the project for you!
This guide explains how to assemble the OpenRC F1 car. If you want to add electronics to make it radiocontrolled another step will be added later.
All files needed including STL´s, BOMlist, drawings, STEP file of the assembly are available here:
Thingiverse
Pinshape
YouMagine
There´s a list of suggested hardware/electronics available here at my website.
There´s a article on Pinshape.com about the OpenRC F1 and if you are unfamiliar with The OpenRC Project you can read this article on Hackaday.com
When you have completed a OpenR/C project you can add it to the OpenRC Buildmap.
Step 1: Introduction to the Project and Starting of With the Chassie Plates
This is mainly an introduction to the project but there are still pieces to print and assemble!
These two plates are the only ones i print with 3 perimiters or more and higher infill rate at about 35%. Most other parts are printed with 2 perimiters with a 10-15% infill at 0.2mm layerheight.
Printed parts needed:
  • Chassie Rear
  • Chassie Front
Step 2: Rear Axle Assembly
Putting together the Rear Axle Assembly and mounting it to the chassie plates.
  • 1pcs - Wheel Axle Holder Left
  • 1pcs - Wheel Axle Holder Right
  • 1pcs - Rear Wheel Axle
  • 1pcs - Spur Gear
Non-Printed parts needed
  • 2pcs - Bearings 12x18x4
  • 4pcs - Countersunk screws M3x8
  • 4pcs - M3 nuts
Documentation available
  • Rear Axle Assembly.pdf
Step 3: Front BOM Assembly (excluding Steering)
Putting together the Front BOM Assembly
  • 1pcs - Front Lower BOM
  • 1pcs - Front Upper BOM
  • 1pcs - Front BOM Block
  • 2pcs - Front Wheel Hub
  • 2pcs - Front Axle
  • 8pcs - Countersunk screws M3x8
  • 2pcs - M3 nuts
  • Front BOM Assembly.pdf
Step 4: Steering and Servo Saver
Let´s get the steering in place and figure out the servo saver.
  • 1pcs - Servo Saver Lower
  • 1pcs - Servo Saver Upper
  • 2pcs - Steering Push Pin
  • 3pcs - Roundhead screws M3x8
  • 2pcs - Countersunk screws M3x8
  • 2pcs - Countersunk screws M3x12
  • 2pcs - M3 nuts
Optional if your adding electronics
  • 1pcs Servo Holder (printed),
  • 2pcs M3x8 CS screws (non-printed)
Step 5: Rear Wing & Diffuser + Rainlight
Short and easy, two parts added to the rear of the car.
  • 1pcs - Rainlight and Diffuser
  • 1pcs - Rear Wing
  • 2pcs - M3 nuts
Step 6: Adding the Body and Details
Now things are taking shape and this is starting to look more like a Formula 1 car, it´s time to assemble the body and add some details!
  • 1pcs - Motor Cover
  • 1pcs - Center Body
  • 1pcs - Center Lid
  • 1pcs - Front
  • 1pcs - Nose
  • 1pcs - Lock Pin
  • 1pcs - Camera
  • 1pcs - Main Turning Vane Left
  • 1pcs - Main Turning Vane Right
  • 1pcs - Rear View Mirror Left
  • 1pcs - Rear View Mirror Right
  • 12pcs - Countersunk screws M3x8
  • 1pcs - Countersunk screws M3x12
  • 13pcs - M3 nuts
Step 7: Finishing Up, Adding Wheels and We Are Done!
We did it. all that´s left is to add the much needed wheels to our F1 car!
Now don´t forget to add your new F1 car to the OpenRC BuildMap.
  • 2pcs - Rear Rim
  • 2pcs - Front Rim
  • 4pcs - Wheel Lock Nut
  • 4pcs - Tire
  • 4pcs - Bearing 8x12x3,5
Optional if you are not 3D Printing the tires
  • 2pcs - Rear Rim For F104 Tire (printed) (search Thingiverse.com for files)
  • 2pcs - Front Rim For F104 Tire (printed) (search Thingiverse.com for files)
  • 4pcs Tires for Tamiya F104 (Ask in the community for a good source in your region)
  • Rear Wheel Assembly.pdf
  • Front Wheel Assembly.pdf
Step 8: Before You Leave, Watch the Entire Build in "Timelapse Mode"
Here´s a timelapse of me building the entire car. Enjoy
