Introduction: Boo! the Halloween Candy Dispenser
Step 1: Find Some Materials.
Here are some materials you'll need.
Cardboard
card stock paper
tape
scissor/ Exacto knife
Marker And thats all you need!
Step 2: Make Part A
Roll up a piece of card stock paper!
Connect 4 cardboard fans too it!
(Connect it tight with tape or Gorrila glue!)
This is Part A
Step 3: Mkae Part B
Find the length by adding how long 2 cardboard fans are, and the stick
Using the length as the diameter, make two circles out of card stock or cardboard.
Make a cylinder out of the two circles.
Open a hole on the top and the bottom and the sides of the cylinder.
Remember you could connect one side of the cylinder but don't connect the other side...... yet!
Step 4: Connect Part a and B to Create Part AB.
Just stick in Part A into the holes in Part B.
Then connect the cylinder.
Step 5: Open a Hole in the Box
Open two parallel holes for now.
Step 6: Time for Gorrlia Glue!
use Gorrila glue to connect the Part AB.
Put gorrila glue on the red areas in the picture.
Step 7: Connect a Hollow Stick
Connect a hollow stick made of card stock paper to the hole of part AB.
Step 8: Make the Finishing Touch.
Make a sole and a hole so the candy will slide down and pop out.
Step 9: Make the Final Finishing Touch.
Add a picture of your favorite halloween beast.
I put Boo! the ghost.
Halloween Contest
