Introduction: Buffalo Wings Recipe
This authentic buffalo wing recipe will produce addictive, crispy and delicious spicy chicken wings every time. More importantly, it's a straight forward and authentic at-home recreation of the buffalo chicken wing recipe that will taste just like the wings from your favorite wing spot in Buffalo, NY. There are many recipes floating around online that claim to taste like real hot wings from New York, but take it from a real New Yorker, these ones actually do.
This recipe uses the steam and bake method, which, if you have the time, results in a higher quality wing. Bars and restaurants are in a rush to get you your order, and so they fry the wing to speed up the process...but don't be fooled, steaming and baking produces one extremely high quality at-home wing.
Step 1: Ingredients
- 1/2 as many whole chicken wings as you'd like to serve
- Salt and pepper
- 3/4 cup Franks Red Hot Original hot sauce
- 1/2 cup butter
- 1 teaspoon cayenne pepper
- 2 teaspoons garlic powder
- 2 teaspoons onion powder
- 1/4 cup brown sugar
- 4 large carrots
- 4 pieces of celery
- 2 1/2 ounces blue cheese
- 3 tablespoons buttermilk
- 3 tablespoons sour cream
- 2 tablespoons mayonnaise
- 1/4 teaspoon sugar
- 2 teaspoons white wine vinegar
- 1/8 teaspoon garlic powder
- 1 teaspoon fresh lemon juice
- salt and pepper
Step 2: Steamer
The first step is to get a large steamer going. Fill the bottom pot with a few inches of water, insert the steamer basket, cover and place on the stove over high heat to start it going.
Step 3: Break Down the Whole Chicken Wings
Chicken wings are made of three parts. Moving from the tip, which I think everyone can identify inward, there's the wingtip, then the wing or wingette itself, and then the drumette.
The chicken wings we're accustomed to eating are made up of the two inner pieces that I just mentioned - the wingette, and the drumette. See the secondary images below for explanation and close-ups.
Break the whole chicken wings down into their three component pieces. Use a sharp knife to cut between the joints that separate each section. Ideally the knife will find its way between the two pieces of each joint cutting the wings apart so that they look like a ball and socket. For some awesome instructions, check out the awesome How to Separate Chicken Wings Instructable.
Throw away the wingtips or use them to make a chicken stock.
Step 4: Steam the Chicken Wings
Place the chicken wings into the steamer basket. Try to keep them from touching each other - yes, this unfortunately means that it will take several rounds of steaming to get all your wings cooked. But, you can't rush excellence!
Cover and cook on high for 10 minutes.
Step 5: Dry the Wings
After 10 minutes, remove the wings from the steamer and let them cool on a cooling rack.
When they are cool to the touch, dry each one individually in a clean cloth or paper towel. There's good logic behind this step! Getting rid of the exterior moisture on the skin means more crisping in the oven when you bake them.
More crisping = better wings.
Step 6: Bake Until Crispy
Arrange the wings on a baking pan so that they're not touching (I'm using tinfoil for easier cleanup, but you can go directly on the pan if you like).
Lightly sprinkle the wings with salt and pepper.
Bake the wings in the middle of the oven at 425 F for 20 minutes on each side, or, until you see significant browning and crisping on the skin.
Step 7: Make the Buffalo Sauce
Buffalo Sauce
- 1/2 cup butter
*Warning* if you keep cooking the sauce you will clarify the butter and all of the solids will settle to the bottom. If this happens, you've cooked your sauce too long and you will have to start over.
Step 8: Cut Carrot and Celery Sticks
Now on to the signature carrot and celery sticks.
Peel, quarter and divide a few large carrots. Slice a couple celery stalks into similar sized pieces as the carrots. Set them in the fridge until it's time to serve.
No, they're not just a token vegetables thrown into the mix to help serious wing eaters better meet the goals of the food pyramid...I like them because they serve as a palate cleanser between wings, can be useful to break the heat of really spicy hot wings, and are a vehicle for more blue cheese dressing when you've just got to have a few more drops of the stuff.
I don't know who thought of adding these wonderful dippers along side chicken wings, but it's pure genius and I wouldn't eat wings without 'em. Thank you Mr. Buffalo!
Step 9: Make Blue Cheese Dressing
- 2 teaspoons champagne vinegar
- salt and pepper
Combine all of the ingredients above in a large measuring cup and mix them together using a fork or whisk. Don't beat the dressing, just try to break apart the chunks of blue cheese.
Step 10: Coat Wings in Buffalo Sauce
Once the wings are done and crispy it's a straight race to the finish.
Coat the wings in the buffalo sauce by tossing them in a large bowl. It's ok to use a hefty amount of sauce in this step, since you can always coat another batch of wings in the sauce that's left over.
Remove the wings from the large bowl and put them in a suitable serving dish.
Step 11: Serve and Enjoy
Serve the wings with blue cheese sauce, carrots, and celery.
The general theory on eating hot wings is to dip a wing in blue cheese dressing and nibble, tear and suck all the meat off the bone. Extra points if you eat the cartilage and clean the bone!
Then, dip and munch a carrot, dip and munch a celery, and repeat 100's and 100's of times.
In case you haven't figured this one out by now, hot wings are especially good when eaten in mass quantity and paired with a cold beer.
