Introduction: DIY Modern Coffee Table
Materials:Cable ties (zip-ties),35 3/4"×24" acrylic sheet (.080), 35 3/4"×24" wire deck, 22"×23 1/2" wire decks
Step 1:
Lay the 35 3/4"×24" wire deck flat with the 35 3/4" raised crossbars facing down (when turned over they will face up). Then attach an 22"×23 1/2" wire deck to each end of the larger wire deck with cable ties. Make sure to leave the cable ties loosely secured.
Step 2:
Attach the other two 22"×23 1/2" wire decks to the center of the larger wire deck with cable ties. Make sure the ties go around all three pieces. Leave the ties fairly loose for later.
Step 3:
Join each of the two middle 22"×23 1/2" wire deck pieces to the outer 22"×23 1/2" wire deck pieces with cable ties, to form a "V" shape as shown.
Step 4:
Adjust all pieces so they line up neatly. Tighten the ties and trim the ends and then flip the whole piece over.
Step 5:
Set the acrylic sheets on the wire deck with the sanded side facing down. They should sit between the 30" raised crossbars.
Optional: Spray paint the cable ties silver to blend in more with the wire decks.Drill small holes in each corner of the acrylic sheet for a small cable tie, to hold it in place on the table top.
