Introduction: DIY Solder Holder
In this instructable you will see how to make very simple yet very effective tool for your working place. This DIY solder holder is adjusted for third hand. It keeps tin solder spool in one place and stops it from rolling all over your table. And the best part it's very cheap!
Step 1: Tools and Materials
Tools and materials:
- scissors;
- a jigsaw;
- drill bits (3mm, 8.5mm);
- glue stick and/or sticky tape;
- universal wood glue;
- super glue;
- third hand;
- a little fan;
- two zip ties;
- heatshrink tube;
- some wood;
- plexiglass;
- sanding sponge or sanding paper.
Step 2: Drawings
FIrst what you will need is to draw all parts. I have made this with SolidWorks. You will see the assembly video in other step. If you are lazy, you can download pdf file with all parts layout and print it.
Before glueing parts layouts on wood, take two parts of it and glue them together, to make it thicker.
Step 3: Preparing
When you print all drawings, cut them out as you can see in photos. Take glue stick and glue the smallest parts on wood. Other two parts needs to be glued on plexiglass.
Step 4: Cutting and Assembling
Step 5: Finishing
After you assemble everything in place, put the solder spool in place. And that's it!
If you want to make your third hand better, put heatshrink tubes on crocodile clips. Those helps to isolate from short-circuiting the PCB and improves the grip. One more thing you can do, is to put a little fan for fume extraction. It's quite simple but very effective.
I hope this will help you. Enjoy and good using!
P.S. Don't forget to vote
Build My Lab Contest
Hardware Hacking
Workshop Contest
Manly Crafts Contest
