Introduction: Duct Tape Belt
I see so many duct tape belts that are very complicated to make and I finally decided to make my own. And it's great if the buckle comes off of a belt you don't use anymore
Step 1: Gathering Materials
What you'll need for this
Step 2: Make the Belt
Now take 2 strips of tape and make sure they'll be long enough for a belt. (I usually eyeball this but you may want to measure where you'll have the belt at and add about 10 inches)
Now keep adding tape to make it thicker. I did this about 4 or 5 times.
Step 3: Add Buckle
Take the belt and cut off the buckle. Then take the tape belt and cut a triangle this will make it easier to put the buckle on it. Now slip on the buckle and stop at the "bottom" of the triangle. Fold the tip of the triangle down and tape it so that the buckle will stay.
Step 4: Make and Add the Loop
Cut off a small strip of tape and fold it in half. Now add three more layers to it. Now take the bottom and top and tape it underneath the belt. This is your loop
Step 5: Cut Holes and Enjoy!
Cut holes in the belt where you'll put the buckle into. Try it on and make sure it's going to fit and there will be a hole for the buckle where you can put it in while wearing it. Now enjoy it cause you worked hard on that
Betabrand Belt Reuse Challenge
Duct Tape Tough Contest
