Introduction: Ender 3 Upgrade Part 3 1MM Nozzle
Hi All,
Ender 3 has a build volume of 220 x 220 x 250 mm, I have never printed anything that was close to 250mm tall. With a 0.4mm nozzle, it would take days to print a functional model this tall.
Based on several youtube videos, 0.6 mm or 1mm nozzle are good options. So I bought both 0.6 and 1 mm nozzles for my Ender 3. To my surprise, cura does not have a proper profile for a 1mm nozzle. and none of the youtube videos has a good reference point to start.
In this instructable, I will share how I created a profile and learnings. This is not the best profile, but a great starting point to start tweaking
- Ender 3
- 1mm Nozzle
- spanner set (6mm and 7mm)
Step 1: Changing Nozzle
- From the menu, heat up the nozzle to 190 degrees
- Using a spanner remove the original 0.4mm nozzle
- Remove boden tube
- Fix the new 1mm nozzle
- Insert boden tube
Step 2: Cura Profile
- Open Cura, select 1mm nozzle and select 0.32mm height default profile
- Start editing the fields directly
- Layer height: 0.5mm
- 50% of the nozzle width
- Initial Layer Height: 0.5mm
- Wall line count: 1
- We do not want to have walls too thick and waste filament
- 1mm width is strong
- Top Layers: 2
- Bottom layers: 2
- Printing temperature: 210 (for PLA)
- We want the filament to melt faster, some might ask to increase this to 230 degrees
- I found 210 as good starting point
- Retraction: 4 mm
- One will have to tweak this based on their printer.I found this value a good starting point
- Print Speed: 40mm/s
- Need time for the filament to melt, reduced speed helps
- Infill: as low as possible, I used 5%
Step 3: Testing
- Best way to test a new profile to its limits
- I used a horse model to print
- The print time was reduced from 1 day 12 hr to 7 hrs
- Based on my observations
- My initial retraction was set at 6mm, which caused gaps at the start of every layer
- Stringing at 215, but at 210, was lesser
- Good print quality with few under-extrusions and bubbles
- the imperfectness of 3d printer are enlarged
Step 4: Conclusions
- 1mm nozzle is good and fast for vases, boxes, etc
- For organic shapes, a 1mm nozzle is not recommended
- Finner details will not be visible
Do share your experience with bigger nozzles
