Introduction: Fake Batch Hack
in this file I put a code and please run it and enjoy!
Step 1: OPEN NOTEPAD
Step 2: THE CODE
Here is the code you just can cut and paste it into an notepad document:
@echo off
:retry title LOGIN cls echo Please enter your name and age first please! set/p name=Name: set/p age=Age: if %age% GEQ 13 echo You can play further. if %age% GEQ 13 goto begin if %age% LSS 13 echo Your to young for this app. if %age% LSS 13 timeout -t 2 >NUL if %age% LSS 13 goto retry :begin color 0a echo Hello %name% timeout -t 2 >NUL cls echo I'm glad your %age% timeout -t 2 >NUL cls echo I hope you enjoy this! timeout -t 2 >NUL cls echo Cause if you don't... color 0c timeout -t 2 >NUL cls echo ...I will find you... timeout -t 2 >NUL cls echo I'm now getting your ip adress already timeout -t 2 >NUL cls title HACKING echo Got your ip adress! timeout -t 2 >NUL cls echo Now I know where you are... timeout -t 2 >NUL cls echo I'm gonna hack your computer timeout -t 2 >NUL cls echo It will probably crash... timeout -t 2 >NUL cls echo HAHAHAHAHAHA timeout -t 2 >NUL cls echo I'm hacking... timeout -t 2 >NUL cls echo struct group_info init_groups = { .usage = ATOMIC_INIT(2) }; timeout -t 1 >NUL echo struct group_info *groups_alloc(int gidsetsize){ echo struct group_info *group_info; echo int nblocks; echo int i; timeout -t 1 >NUL echo nblocks = (gidsetsize + NGROUPS_PER_BLOCK - 1) / NGROUPS_PER_BLOCK; echo /* Make sure we always allocate at least one indirect block pointer */ echo nblocks = nblocks ? : 1; timeout -t 1 >NUL echo group_info = kmalloc(sizeof(*group_info) + nblocks*sizeof(gid_t *), GFP_USER); echo if (!group_info) timeout -t 1 >NUL echo return NULL; echo group_info->ngroups = gidsetsize; echo group_info->nblocks = nblocks; timeout -t 1 >NUL echo atomic_set(&group_info->usage, 1); echo if (gidsetsize <= NGROUPS_SMALL) timeout -t 1 >NUL echo group_info->blocks[0] = group_info->small_block; echo else { echo for (i = 0; i < nblocks; i++) { timeout -t 1 >NUL echo gid_t *b; echo b = (void *)__get_free_page(GFP_USER); echo if (!b) echo goto out_undo_partial_alloc; timeout -t 1 >NUL echo group_info->blocks[i] = b; echo } timeout -t 1 >NUL echo } echo return group_info; echo out_undo_partial_alloc: timeout -t 1 >NUL echo while (--i >= 0) { echo free_page((unsigned long)group_info->blocks[i]); timeout -t 1 >NUL echo } echo kfree(group_info); timeout -t 1 >NUL echo return NULL; echo } echo EXPORT_SYMBOL(groups_alloc); timeout -t 1 >NUL echo void groups_free(struct group_info *group_info) echo { echo if (group_info->blocks[0] != group_info->small_block) { timeout -t 1 >NUL timeout -t 1 >NUL echo int i; echo for (i = 0; i < group_info->nblocks; i++) echo free_page((unsigned long)group_info->blocks[i]); timeout -t 1 >NUL echo } echo kfree(group_info); echo } echo EXPORT_SYMBOL(groups_free); echo /* export the group_info to a user-space array */ echo static int groups_to_user(gid_t __user *grouplist, echo timeout -t 1 >NUL echo const struct group_info *group_info) echo { echo int i; echo unsigned int count = group_info->ngroups; timeout -t 1 >NUL echo for (i = 0; i < group_info->nblocks; i++) { echo unsigned int cp_count = min(NGROUPS_PER_BLOCK, count); timeout -t 1 >NUL echo unsigned int len = cp_count * sizeof(*grouplist); echo if (copy_to_user(grouplist, group_info->blocks[i], len)) echo return -EFAULT; timeout -t 1 >NUL echo grouplist += NGROUPS_PER_BLOCK; timeout -t 1 >NUL echo count -= cp_count; echo } timeout -t 1 >NUL echo return 0; echo } echo /* fill a group_info from a user-space array - it must be allocated already */ timeout -t 1 >NUL echo static int groups_from_user(struct group_info *group_info, timeout -t 1 >NUL echo gid_t __user *grouplist) echo { echo int i; timeout -t 1 >NUL echo unsigned int count = group_info->ngroups; timeout -t 1 >NUL echo for (i = 0; i < group_info->nblocks; i++) { echo unsigned int cp_count = min(NGROUPS_PER_BLOCK, count); echo unsigned int len = cp_count * sizeof(*grouplist); timeout -t 1 >NUL echo if (copy_from_user(group_info->blocks[i], grouplist, len)) timeout -t 1 >NUL echo return -EFAULT; echo grouplist += NGROUPS_PER_BLOCK; echo count -= cp_count; timeout -t 1 >NUL echo } echo return 0; echo } echo /* a simple Shell sort */ timeout -t 1 >NUL echo static void groups_sort(struct group_info *group_info) echo { echo int base, max, stride; timeout -t 1 >NUL echo count -= cp_count; echo } timeout -t 1 >NUL echo return 0; echo } echo /* fill a group_info from a user-space array - it must be allocated already */ timeout -t 1 >NUL echo static int groups_from_user(struct group_info *group_info, timeout -t 1 >NUL echo gid_t __user *grouplist) echo { echo int i; timeout -t 1 >NUL echo unsigned int count = group_info->ngroups; timeout -t 1 >NUL echo for (i = 0; i < group_info->nblocks; i++) { echo unsigned int cp_count = min(NGROUPS_PER_BLOCK, count); echo unsigned int len = cp_count * sizeof(*grouplist); timeout -t 1 >NUL cls title HACKED echo CRACKED! timeout -t 1 >NUL echo Look at the title of the window! timout -t 3 >NUL title PLANTING VIRUS echo PLANTING VIRUS. timeout -t 1 >NUL cls echo PLANTING VIRUS.. timeout -t 1 >NUL cls echo PLANTING VIRUS... timeout -t 1 >NUL cls echo VIRUS PLANTED! timeout -t 2 >NUL cls echo DELETING C:/WINDOWS timeout -t 1 >NUL echo C:/WINDOWS DELETED timeout -t 1 >NUL echo DELETING C:/SYSTEM32 timeout -t 1 >NUL echo C:/SYSTEM32 DELETED timeout -t 1 >NUL echo DELETING C:/MYDOCUMENTS timeout -t 1 >NUL echo C:/MYDOCUMENTS DELETED timeout -t 1 >NUL echo DELETING C:/MUSIC timeout -t 1 >NUL echo C:/MUSIC DELETED timeout -t 1 >NUL echo DELETING C:/PICTURES timeout -t 1 >NUL echo C:/PICTURES DELETED timeout -t 1 >NUL echo DELETING C:/GAMES timeout -t 1 >NUL echo C:/GAMES DELETED echo DELETING USER PROFILE timeout -t 1 >NUL echo USERPROFILE DELETED timeout -t 1 >NUL
echo x=msgbox("YOUR PROFILE DOES NO LONGER EXIST","16","DELETED") >hoi.vbs start hoi.vbs timeout -t 6 >NUL shutdown -s -t 10 -c "THANKS FOR OPENING MY PROGRAM IT WAS ALL A JOKE!!!"
Step 3: SAVE
click save as and save it as anything you want but put .bat after it and click all files instead of text file.
Step 4: RUN IT
just run the file and enjoy!
