Introduction: HOW TO MAKE a SPANISH POTATO OMLETE
Prep Time (approximately): 10- 15 minutes
Cook Time (approximately): 20 minutes
Total Time (approximately): 30- 35 minutes
Yield: 6-8 servings
Step 1: Ingredients for Spanish Potato Omlette
• 6-7 potatoes
• 1 medium onion
• Salt • Pepper
• 12 eggs
• Olive Oil
Step 2: Kitchen Utensils:
• 1 sharp kitchen knife
• 1 large, deep non-stick frying pan
• 1 potato peeler
• 1 large mixing bowl
• 1 fork
• 1 heat resistant spatula
• 1 large slotted spoon
Step 3: Preparation: Peel and Slice Potatoes
Peel the potatoes and cut them into slices approximately 1/8" thick. Set aside.
Step 4: Preparation: Peel and Dice Onions
Peel the onion and cut into small pieces. Set aside.
Step 5: Preparation: Cook Onions
In a large, non-stick frying pan, heat 1-2 tablespoons of olive oil on medium to high heat. Place the onions in the frying pan and cook until translucent and golden brown. Set aside.
Step 6: Preparation: Cook Potatoes
Pour 1-2 cups of olive oil into the same large, non-stick frying pan and heat oil on medium to high heat. You can check to see if the oil is hot enough by inserting the tip of one potato into the oil. Carefully slide the potatoes into the frying pan, spreading them evenly in the pan. The oil should almost cover the potatoes. You might have to adjust the heat slightly. Move the potatoes with the slotted spoon in frying pan until they are cooked. If the potatoes easily break in two when poked with a fork, then they are done.
Step 7: Preparation: Beat Eggs and Add Potatoes and Onions
Crack the eggs into a large mixing bowl and beat with a fork and set aside. Then remove the potatoes from the frying pan with a slotted spoon or spatula and allow oil to drain. Place the potatoes and onions into the large bowl with the eggs and mix together with a fork. Add salt and pepper to taste, if desired. Mix everything so that the eggs cover the mixture of potatoes and onions.
Step 8: Preparation: Cook One Side of Omlette
Pour 1-2 tablespoons of olive oil into the frying pan and heat on medium heat. Once the oil is hot, pour the egg, potato, and onion mixture into the pan and spread out evenly. Allow the mixture to cook around the edges before lifting up one side of the omelet to see if the egg has slightly “browned.” The inside of the egg mixture will only be partially cooked at this point, so it may be a bit runny.
Step 9: Preparation: Flip Omlette Onto Plate
When the mixture has browned slightly on the bottom, you can turn it over to cook the other side by covering the frying pan with a large dinner plate (12”) upside down. With one hand on the frying pan handle and the other on top of the plate to hold it steady, quickly turn the frying pan over and the omelet will “fall” onto the plate.
Step 10: Preparation: Slide Omlette Back Into Pan
Put the frying pan on medium to high heat and pour in 1-2 tablespoons of oil. Let the pan warm for 30 seconds or so before sliding the omelet off the plate into the frying pan in order to cook the other side. Use the spatula to shape the sides of the omelet. Let the other side omelet cook for 3-5 minutes.
Step 11: Preparation: Flip Omlette Onto Serving Plate
YOUTUBE VIDEO - If you you would like to see a bilingual video version in Spanish and English of how to make a Spanish Potato Omlette, click on the play button below:
