Introduction: Halloween Shot Glass
This is my instructable. WARNING! THIS IS A FIRE AND HEALTH HAZARD. I TAKE NO RESPONSIBILITY FOR WHAT EVER YOU DO WITH THIS PROJECT.
Step 1: Tools and Materials
My project is making a Halloween Shot Glass. These are the pictures I have. You take a soldering iron a bucket filled it with ice and water. I think all the ice melted but that doesn't mater. The bucket of water and ice or just water is to cool down the iron to make it safer to use. It may not protect you if you do something stupid with it.
Step 2: Getting Ice
I recommend you not to drink anything from the project and the shot glasses you make because the soldering iron may leave stuff behind and what ever it leaves behind may not be good for you. You take a zip lock bag or what ever you don't want anymore that can hold water. Make sure that nothing leaks out because it's suppose to be a block of ice when you get it out of the freezer. Check to see if the water is frozen before working on no it. Just because the ice is hard doesn't mean that the water is completely frozen.
Step 3: Working on Your Block.
You can usually tell by looking at it if you see any bubbles. If the bubbles are there or moves around then you have more freezing to do. Once the ice is done take it out and put it on a plate. A lot of plates can't handle heat so be careful. Once you have a plate, a soldering iron, and bucket of water and ice or just water then you can start working on your ice block. Good Luck.
PS. I don't know how hard or expensive this project is. Don't get frustrated or break your budget. It could be easy and not expensive. It all depends. Something bad may happen to what ever you use. I also take NO RESPONSIBILITY.
