Introduction: Hammock Chair
Hi I'm kenny vanbrabant
and I am a student at the high school of Kortrijk
There I follow the training industrial product designer
I have been ordered to create a hammock chair that I can take everywhere
and less than 5 kg of weight has
In addition, they recommended to me to bend the wood where you have a hollow bottom Gets
the material necessities
MDF board
a piece of textile
a plate- like paperboard
a piece of rope
one piece construction hold
screws
shoelace
a piece of wool
2 clamps
2 O rings
Step 1: Wooden Frame
As you can see I above a wooden frame made from MDF in doing so, I made 6stukken
1 pieces as support with the sizes 60 cm used as grain
2 pieces small pieces at the ends with the sizes 19 cm
2 pieces that are a bit longer in order to obtain my leaf shape with sizes 30 cm
1 large piece in the middle with sizes of 36 cm
In each piece I have a slot made where I can insert the 2 pieces which slot is in the middle of each piece and is as wide as the thickness of my MDF
Finally I have everything nicely glued with strong wood glue
Step 2: De Steel
After I've made
there of course could not have that shape steel lack that I made from construction wood I mounted de steel on the ends with screws and wood glue
To make sure that everything stays securely in place I have it still clutching and again everything beautiful equal sanded
Step 3: Wood Pleats
Then I folded cardboard wood yet before that I let the plates completely
soaking by water to make it easier to do bending then I the platten attached
with small screws to the wood construction
Step 4: Protection
Then I 4 holes
drilled in the bottom where I still have a piece of metal plate mounted
as extra sturdy heid and all taped up with duk tape
as additional protection for the water
Step 5: Finishing of the Hammock Chair
Then I stuck a piece
of wool on the seat, enjoy a soft bottom and finally finished with a green fabric that I have sewn to each other and to top it off I have to work a laces used as veins
Step 6: Mount Rope
the ropes are in 2
shared the first part that is always the swing hangs which is that a piece of 1 meter long where there hangs a O ring O ring that stays in place by hanging because the clamped by a clamp piece
and the second part
of 7.5 metres become made a fixed a pulley with a knot further confirm your also the pulley to the O ring for you to hang them together also to use the pulley to set height by the rope through cuttings and at the desired height to make a button in
