Introduction: Home Made Hot Tub
I do not take responsibility for any injuries or emotional trauma from this hot tub device (why emotional? Just covering all the bases)
Parts list: old air tank, air compressor, two hoses, fire wood, air hose, fire pit
you will also need two nipples that are one yard long (Or longer our hose slightly melted) that will fit your tank with a size converter from the nipple size to 3/4 inch, and one threaded connector that fits the nipple ( 3/4 inch so that the hose will fit )
example: 1" tank outlet = 1" X 3/4" converter
1/2" tank outlet = 1" X 3/4"
you get it I'm sure
IMPORTANT
Your tank needs to have an inlet and outlet.
i used a propane tank but i do not advise for obvious reasons.
(go to page for instructions on propane tank preparation)
BUT SERIOUSLY I DO NOT TAKE RESPONSIBILITY FOR INJURY'S DUE TO PROPANE TANK ACCIDENTS
Have you ever thought how nice it would be to have a hot tub, so you go over to your computer and think "hmmm... it seems like they can't be that expensive... its only fiberglass... WHAT??? a thousand bucks???"
i have come up with a way to bring down those damn hot tub companies! make your own
CAUTION: the water coming out of your hot tub may exceed boiling point BE CAREFUL
Do not gauge temperature with your hand!!!
if you have a thermometer, terrific, if not, your wife should have a meat thermometer in the kitchen or you have one for your BBQ.
Step 1: Prepare Tank
Find the inlet and outlets on your tank and screw the nipples into the inlet and outlet.
Now connect the nipples into the tank. One nipple should have a piece with two female inlets. Next connect the hose to the nipple. One hose should be connected to the nipple with the other end in the pool.
Now you can build a fire and put the tank on top with the nipples away from the fire so they dont melt
We used a 14 gallon tank propane tank we got for free
Step 2: Heat Pool
stick the hose in the pool and turn the water on
you can turn the hose up to cool down the temperature
and turn it down for hotter
