Introduction: How to Make a 50 Dart Belt for Your Nerf Vulcan
Step 1: Items Needed
• 2 Nerf Vulcan Dart Belts • Pocket Knife • Small Phillips Screwdriver
Step 2: Take the Screws Out
Line up one end of each dart belt with the bullets facing away from you. Take the screws out of each end and take the top off the end. Leave the straps like they are.
Step 3: Careful You Have a Knife!
Take the end of the right side off completely and throw it away unless you plan on putting it back on. Now the strap will have 4 holes on it, use your knife to cut the middle 2 holes out.
Step 4: Connect the Two Belts
On the left belt you will see the same 4 holes in the strap with 4 sharp pegs in the holes. Next to that there is a rectangle peg that the strap on the right will fit just perfectly.
Step 5: Nearly Done
Now put the cap from the left strap on and put the screws in and your done! Since the dart belt is now able to hold 50 darts, the Vulcan motor isn't strong enough to pull the belt in so you will have to hand feed it. Also, the dart bin isn't big enough for 50 darts and still shut, this is why you have to hand feed it.
Step 6: You're Done!
Enjoy the fifty dart belt to its full extent!
