Introduction: How to Make a Duct Tape Wallet
This wallet includes an ID holder,money pocket,and pockets for holding cards and other stuff.
Step 1:
Cut 8 strips that are about 8 inches long. Don't worry if the strips are uneven. You can trim them down later.
Step 2:
Take one of your strips and flip it over so that the sticky side faces up. Next put another strip on top of it sticky side to sticky side leaving about a quarter of an inch of stickiness on the bottom. The flip the strips over and put another strip on the remaining stickiness (sticky side to sticky side. Flip it over again and put another strip on the remaining stickiness. Repeat with the remaining strips. You should end up switch a panel with a little bit of stickiness on the top and bottom.
Step 3:
Fold the sticky ends into themselves so that you have a panel with no stickiness. If you have another color of duct tape cut a strip that is the same length as your panel,cut it in half lengthwise,and put the strip on the top of your panel then fold it over do that there is a little bit of blue on your panel.now fold your panel in half so that you can see the blue. Next cut a strip of white tape that is the same length as the folded wallet. Cut another white strip for the other side of the folded panel.
Step 4:
Fold the wallet in half. Then cut two strips of blue tape that are the same length as half of the wallet. Then cut another strip that is the same length as half of the wallet. Then cut two strips that are the same length as the height of the strips. Then put the two strips(same length as half of the wallet) together sticky side to sticky side. Next put strips of tape on 3 sides of the small panel you just made. Now tape it onto the inside of your wallet near the top. Repeat if you want more pockets.
Step 5:
Cut a piece of a ziploc bag that is the same size as the other half of the wallet. Then cut 3 strips to fit around 3 sides of the ziploc bag and tape it to the wallet with the untaped side facing inwards. Tada! You now have a wallet!!
Step 6: Decorate
Decorate your wallet! Leave a comment with a pic of your wallet! Curious to see what you guys come up with! Thank you for reading! :)
