Introduction: How to Choose New Tyres
Good, new tyres are a must when it comes to navigating the roads any season. But when it comes to choosing out a good set of new tyres, most people do not know where to begin. With all of the different brands, sizes and types available, navigating the tyre stock can be quite intimidating. Continue reading below to discover how to choose the perfect tyres for your vehicle.
Do I Need new Tyres?
One of the first things you should do each season is give your tyres a good inspection. Since many different variables play into how long a tyre lasts, it’s not really possible to give an overall estimate of how long the typical lifespan is. Besides just the factors or the brand, make and model, the life of your tyres will also depend on the past few months weather conditions, how far you drove, and where you drove. But it is possible to tell if you need new tyres on your own by using some simple measurements. To measure tyres you can use a tool called a tread depth gauge, or you can simply use a 20p coin.
The 20p Method
Using a 20p coin to measure tyre depth is an easy way to give you a quick estimate on your tyre depth, letting you know if a trip to the tyre shop is needed.
● First, for an accurate measurement, be sure your car is on level ground with the hand brake on.
●Take a 20p coin, and place it between the grooves of the tread.
● If you can see some of the outer edge of the coin, then your tyres are worn out, and not road legal.
How Many?
The first thing to ask yourself when you realize you need new tyres is how many. If you are just replacing one tyre,for example, because of a flat, it is best to use a new one with the same or similar brand, speed rating and load capacity as the old one. The same goes for if you need to replace 2 or 3 tyres only - they must be either the same or similar to your other tyres, r you will end up with an uneven balance. Your tyre dealer will be able to help you choose similar tyres in these scenarios.
If you are changing all of your tyres however, you can be open to a lot more options and choices in tyres.
How Big?
Determining the size of your tyres is important if you’d like a similar size or bigger sized tyre. To find the size of your tyre, you can use a few methods:
● Check the sidewall: The characters on your tyre tell you what size it is. look for the letters surrounding the rims of your tyres and bring these numbers along with you. A tyre specialist will be able to help you read them if you don’t know what they mean.
● Look in your vehicles owner manual if this your first time changing tyres n a new vehicle.
● You can also check the tyre placard - usually located in the glove box, fuel door, or other door edge of your car.
Choosing a size
Choosing a tyre size can change the way your car drives. If you’re happy with your current tyres, then obviously you’d want to keep the same size. But if you’d like a change, consider these options:
● Improving ride quality/handling: If you find yourself having to consistently avoid the smallest bumps in the road, or constantly steering your wheels, you might find it helpful to choose a lower profile tyre. These tyres can improve stability and handling because of their wider tread and lower sidewall.
● Improving response and handling: If you want better tyre control, then Plus Sizing your tyres might be a good option. These tyres are generally the same height as your old ones, but with a shorter sidewall, making them quicker to respond.
● Performance and ride quality, especially in bigger SUVs or trucks, can be improved by upsizing your tyres. Choosing upsizing for your truck can even improve load capacity and traction.
Knowing exactly which would be best for your car or truck is best discussed with a tyre specialist like Atlas Auto Service. They will be able to help you decipher what your car can handle, and if it is able to change new tyre type according to your road conditions, budget and performance.
