Introduction: How to Get Rid of Stink Bugs Without Leaving a Bad Smell
We all know them and for some of us it's a big problem. Stink bugs these little insects are gross and you probably don't want them in your house and if you know stink bugs then you also probably know where their name comes from. When you smash a stink bug it releases a horrible "stink" that makes your house smell bad and it attracts more Bugs.
Step 1: You Must Stop the Invasion Before It Starts
It starts with just one or two but don't smash that one thinking "aw it's just one whos cares" that one will turn to one-hundred you must remove the stink bug without causing a stink. first you need supplies
You'll need:
1 clothesline clip( you can get a bunch at target for $2.00)
since it's close to easter you'll need, 1 plastic easter egg ( you can get 30 at dollar store for $1.00)
and Glue of any sort, Hot Glue if you need it on the dot.
Step 2: Time to Crack Some Eggs...
most easter eggs have a little piece sticking off holding the two halves together if so Break/cut it apart so you have two separate halve.
Step 3: Hold Open Your Clip
sorry for bad image
Step 4: Glue the Two Halves to Each End of Clip
Glue Each End Of the clip to the brim on each halve
Pic Coming soon
Step 5: Use It
when you open and close it it should create a little capsule to enclose the bug Where you Can safely dispose of it Remember Even though you're outside do not crush it just let it go.
pic coming soon
Hack Your Day Contest
Full Spectrum Laser Contest 2016
Pest Control Challenge
