Introduction: How to Make Easy Earrings With Headpins and Eyepins for Valentine’s Day
Here you may see an easy earrings tutorial for beginners that show you how to make earrings with headpins and eyepins in an unusual way, including the way to make a wrapped loop.
Step 1: Supplies Needed for Making Earrings With Headpins:
Colorful Acrylic Beads
6mm Bicone Glass Beads
Headpins
Eyepins
Earrings Hooks
Chain
Jewelry Glue (optional)
Round Nose Pliers
Wire Cutter Pliers
Side Cutting Pliers
Step 2: Make a Beaded Link With Eyepins
1st, string a 6mm bicone glass bead onto the eyepin;
2nd, make a wrapped loop over bead with the leftover pin part. Make two beaded link totally.
Step 3: Add the Chain
1st, prepare two 41-link chain strands;
2nd, open the simple loop on eyepin and hook the center link on chain (you can use a pin to help find the chain center). Repeat the same processes with the other earring piece.
Step 4: Make the Heart Bead Dangle
1st, pass two headpins through the heart bead;
2nd, string the last link of each chain on headpin respectively;
3rd, roll the remaining pin part to the left and right by using pliers;
4th, stuck the chain link at the last roll;
Step 5: Anchor the Head of Pin With Dab of Glue.
Step 6: Attach the Earring Hooks
Open the loop on earring hook and attach the earring dangle.
Step 7:
Done!
If you've got fifteen minutes and a few bead leftovers, just try making earrings with headpins and eyepins! These will take longer to read than to actually make the earrings.
