Introduction: How to Create Pizza Bagels
Coming home from school, and are hungry. Nothing is in the fridge, well then create pizza bagels. These are easy to make, filling and kid-cooking skills friendly. These are easy to make, and perfect for any situation, such as sleep-overs. Here’s how to create them.
Time: 1 hour 45 minutes
Safety Considerations: Wear Oven Mitts
Step 1: Keep Area Clean
Make sure that the area you will be creating the pizza bagel is clean and unnecessary clutter is removed. This will decrease the chances that you injury yourself during the process.
Step 2: Wear an Apron
Wear an apron around your body.This will decrease the chances of dough or any ingredients getting on your clothes, keeping them clean.
Step 3: Gather Your Materials
Make sure that all your materials are in one place in the kitchen. This will make it easier for you to create the pizza bagels, since you do not have to move around to gather materials.
2 bowls1pot
1 knife
1 spoon
1 cooking brush
1 baking tray
wax paper
1 pair of oven mitts
Step 4: Set Up the Kitchen
Set-UP the kitchen accordingly to wear which process of the creation will take place.
(Pots on the Stove, etc.) This will save you time when creating the pizza bagel.
Step 5: Gather Your Ingredients to Create the Dough
5. Make sure you have all your ingredients before starting to create the bagel. This way you are more organized and can concentrate on the pizza bagels, instead of running back and forth throughout the kitchen, since you don’t have the ingredients.
1 1⁄2 cups of water
2 packages of yeast
1⁄2 ounces of salt
3 1⁄2 cups of flour
2 quarts of boiled water
1 egg white
dried onion or garlic powder
Step 6: Mix Ingredients Together
The first step of creating the dough is get a bowl and mix 2 packages of yeast, sugar and warm water together, and let it stand there for 3 minutes
Step 7: Mix Ingredients Together
Next, mix 2 cups of flour with ½ ounces of salt in a large bowl and add the yeast mixture. Then stir until the dough becoming firmer. You should slowly add the rest of the flour to the dough.
Step 8: Let the Dough Rest
After you have created the dough place a plastic seal on top of the bowl, and let it rest until it has doubled in size. This can take up to a hour.
Step 9: Knead the Dough
After the dough has doubled in size, take it out of the bowl and knead the dough on a floured surface. It is recommended to knead the dough for 5 minutes.
Step 10: Divide and Shape the Dough to Make a Bagel
After you have kneaded the dough, divide the dough into separate spheres.
Step 11: Let the Dough Rest
After you have done this allow the dough to rest for 4 minutes. In the meantime bring 2 cups of water to a boil. Once the water has boiled, lower the heat of the water so that it is shimmering.
Step 12: Boil the Bagels
Drop 2 or 3 bagels into the water for about 45 seconds, turning the bagels over after 22 seconds. During this time, you should preheat the oven to 350 degrees. After the bagel has cooked, drain it and place it on a greased baking sheets.
Step 13: Brush an Egg on the Bagel
Crack an egg and scramble it. Afterwards brush the bagel with a beaten egg. You can add garlic powder, or dried onions to the bagels.
Step 14: Bake the Bagles
Place wax paper onto a bake tray, and then place the bagels on it. Then wear oven mitts and put the bagels in the oven for 35 minutes. Every ten minutes put oven mitts and turn the bagels over for even browning. The bagels are done when they brown and shiny.
Step 15: Gather Ingredients
Gather all of your ingredients to add to your pizza bagels.
-shredded mozeralla cheese
- marinia sauce
-half of a red pepper
- corn
Cut the bagel in half
Step 16: Add Ingredients to the Baked Bagels
If the bagels are done let them rest for 5 minutes. You should check if the bagels are crispy. This will insure that the bagel does not get soggy when you add tomato sauce on it. Then cut the bagels in half with a knife, spread tomato sauce on the bagel, and add slices of red pepers to it. You can add as many ingredients as
Step 17: Bake the Pizza Bagel
Once you have added Place it on a baking tray Bake for 10 minutes, or until the cheese is baked and bubbly
Step 18: Bake the Pizza Bagels
Place your custimoized pizza on a baking tray with wax paper. Place oven mitts on your hand and place the baking tray in the oven. Let the pizza bagels bake for 10 minutes, or until the cheese is baked and bubbly. After it is finished baking take it out of the oven, and switch the oven off. Let the pizza bagel rest for 5 minutes.
Step 19: Remove the Pizza Bagels From the Wax Paper
After the pizza bagels have rested, take it off the wax paper and place it on a plate. Eat and Enjoy the pizza bagel.
