Introduction: KN-1 (K'nade, or the Knex Grenade-1)
This is the first one in my new series the KN series which will feature war-zone grenades, my other ones were prototypes. This one, after being heavily modded is finally avaliable in a small package and will allow some good fragging, featuring 18 yellow rods, this baby is a weapon of mass distraction, i mean destruction! I know it looks like FAIL! but build it then test it, if it doesn't work, then the bands or not tight enough or are not couped up at the end, because when it is at the end it will drag the rods out like in the picture.
Build this!!! Thannk you to tigernod for the lovely chat and the idea of making this.
It started as 182 pieces clumped together, which FAILEd! but this is a SUCCESS!!!
Step 1: Pieces
Short piece count
you will need:
18 yellow rods, or any other rod you favor, not green or white though, for grey you need 2 bands
1 loose #64 band
a wheel outside not inside
Step 2: Make
First you grab your rods and hold them tightly making sure every rod on the outside is level.
Then, you need to put your rubberband around and around and around and around and around(5 times) the rods at the very end and you need to still hold tightly.
Lastly you put the wheel on for the "pin"
Step 3: Priming
Unlike others, this needs to have a priming step, because it is a fouundation of it actually working.
Ypu need to put the tyre up to the very top, but look inside the tyre, there should be 3 sectiions, the middle on sticking out, you need the bottom on to be touching one side and the other slightly higer( more or less for the last bit). And then throw with force to get it flying into your opponents face and making him feel sorry.
