Introduction: K'NEX Robotic Suit Mark II
See more pictures at https://www.facebook.com/pages/Alex-Nguyen-as-KNex-Robot/153178024715380
Step 1: Helmet
The helmet is the only piece I kept from my original suit. It also has eye flaps that can open and close.
Step 2: Torso
This piece was definitely the most challenging. It covers my whole torso, leaving only holes for the arms and head. However, it was still flexible enough that I could lean side to side and bend without limitations. It also opened along the center of the front so that I could easily step inside and put it on.
Step 3: Arms
The arms were the easiest part of the suit to create. I could fully bend my elbows, while the wrist was also able to rotate and bend. The fingers could move and grasp as well. The shoulders were also modified so that I was able to move my arms 360 degrees and even rotate them.
Step 4: Legs & Feet
The legs were improved so that I could walk normally, as well as run. I was able to bend my knee 90 degrees and also pivot on my ankle. Like the torso, my legs opened down the center and the foot folded out so that I could step in to wear it.
Step 5: Final Product
Once I had built all of the pieces, I attached them together and produced the result below. In order to hang it, I built a frame out of PVC pipes and used several elastic cords to suspend it from the shoulders. Putting it on was relatively easy, as I was able to open the torso and legs and just step inside.
Finalist in the
Halloween Epic Costumes Challenge
