Introduction: Knex Browning M1919 Chain-fed MG
THIS.... is the first k'nex browning posted on this site. it isn't to big which can be good and bad. Good for people with not much k'nex. or Bad because it doesn't look the right size to seem cool. It is a chain fed MG which fires at about 2-4 bullets a second.
erm....
Pro's
Looks
Sights
Firing rate
Can fire continuously for ages depending on length of chain.
No's
Long Reload time
Range (10-20ft)
USES MODDED PIECES!!!!! AAAARRGGHH!!!
Ahem. Excuse me. I'm surprised you've read this far.
Anyway, Let's start building!
Step 1: Chain
Ok. Let's get the boring part over and done with. THE CHAIN!!!
1.Individual bullet (note the 2 chain links)
2.All connected
Step 2: Handle
Now to start on the gun. First of: The Handle
1.Make 2.
2.Add Blue and Yellow Rods to one of them.
3.Make 2.
4.Connect one of them to the thing that you added the Blue and Yellow Rods to. (Picture 2)
5.Add either Y Connectors, Blue Spacers, End Clips OR Grey Connectors on the Blue Rods. Then wrap the wire from the Motor round the Rods.
6-7.Add the other 2 sides back on.
8.Add Blue Rods and Blue Spacers to the controller.
9. Attach it to the rest of the Handle
Step 3: Body
Now for the Body and all the components that make it work.
1.Make 2.
2.Add Green Rods onto the Sticky Outty Things...
3.Make these. They are 5 layers wide.
4.Add.
5.Make this.
6.Replace the Orange Connectors with something else if you don't want the Bipod.
7-8.Insert it in and attach the Handle.
9.Attach the other side on now.
10.Get 2 Blue Rods and put them where circled. This will stop the 5 layered things from flopping about.
11.Make This. The Rear Sight. Sorry about the blur.
12.Attach.
13.Make this. You don't have to mod the Yellow Rod.
14.Attach.
Step 4: Barrel
The confusing part. MODDED PIECES NEEDED!! :(
1.The modded pieces. 4 Grey Rods and 2 Yellow Rods.
2-3.Make this. Use the 2 modded yellows.
4.Make 2 of these. yes they are confusing. I'm sorry i couldn't show you the pattern. I would never be able to put it back again. Either use Snowflakes or try to figure it out for yourself.
5-6.Connect.
7.Connect.
8.Attach to gun.
9-10.Now the barrel will be a bit flimsy. So i suggest using a rubber band to pull it up.
Step 5: Tripod (Optional)
You don't have to build this but i think it's cool.
1.Build 3.
2-3.Close ups.
4-5.Build this.
6.Attach all 3.
7.Build.
8.Add.
9-10.Attach.
You're done!
