Introduction: Light Bulbs Candle Holders
Want to re use those shot light bulbs rather than throw them away. Why not make them into a Halloween decoration.
You will need:
an old light bulb
a candle stick
a screwdriver
coarse sandpaper
A saw
WARNING: This Instructable involves breaking glass and sharp metal, therefore I would advise protective gloves and goggles to be worn during the first couple of steps. Make sure you have a responsible adult with you if you are under 18.
Step 1: The Light Bulb
CAUTION: Use Protective GLOVES and GOGGLES
To remove the bottom metal area of the light bulb is very tricky. Cut the top of the metal off ( approx. 3 rings down) as this should be just before the empty space stops. When that has been removed you will need to carefully cut the rest of the metal away by prising it away from the metal on the inside. The metal can be very sharp so be careful, please
Step 2: Breaking the Glass
CAUTION: Protective GLOVES and GOGGLES to be warn.
Use a screwdriver to gently break the fill tube and remove the filament. Now break around the top of the glass until there is enough space for your candle stick to fit into the bulb. Again please be careful and pick up any glass that breaks.
Step 3: Sanding
CAUTION: Wear Protective GLOVES and GOGGLES
Now take the sandpaper and gently sand around the sharp edges of the bulb ( this can be time consuming). You want a smooth edge not a pristine finish. It's okay if the glass is broken further down at one point than another. Once it is smooth make sure that all the glass is gotten rid as it is dangerous. Now wash pour some water in the bulb to wash it out. Then wait for it to dry.
Step 4: Wax
In order to make your candle stay up right in the bulb you must first pour in some wax. Simply just burn a candle and pour the wax into the bulb. Now you have done the place the candle stick into the wax and hold it up right by placing your finger on the top of the candle (if the wax at the bottom has hardened simply heat it back up).
Step 5: Decoration
For decoration you can melt wax down the side of the bulb and place it on top of something ie a Witch's potion
The bulbs cannot stand up by themselves they must be held in something,
Also do not move the bulb once the candle is lit as the bulb get quite hot.
Halloween Decorations Challenge
