Introduction: Ninja Blinding Egg
Make and blinding egg you can throw at your opponents.
Step 1: Get Your Supplies
First off you need a
-egg
-tape(I used electrical tape0
-cork screw or nail
-hose or water source
-blinding mixure(i used flour to demonstrate)
(This is my first instructable:)
Step 2: Make a Opening and Empty the Egg
You can use a corkscrew or a nail to make a hole in the top. I made the hole a little bigger for demonstration. Then turn it upside-down and shake out its (innerds.)
Step 3: Rinse It Out
I just took it over to the hose and rinsed it out then i dryed it on my shirt:)
Step 4: Fill With Blinding Mixure
For the purpose of demo. i used flour.
-Just grab some flour
-Either used paper technique(see pic)
-Or used Pour technique(see pic) use this if you made the hole bigger.
-When your filling it, shake it a little so it settles and you can add more
-You could add for hours because flour is so powdery so only you can deside when its full
Step 5: Seal and Decorate
Honesly i think this is a "ok" way of sealing but by far not the best. If you have any suggestions post them and I'll consider them:)
But what you want to do is first make sure you brush off all the flour from the outside of your egg and then you want to cut two pieces of tape and make an "X" pattern over then opening on you egg.
Then if you feel like it you can write something on you egg.(I tried spray painting one once and it was to "sticky for me even after it was dry)but do whatever you would like.
Step 6: Test It Out
I walked back in my woods and threw it at a tree. Usually it will make a bigger pattern but i was close to the tree because i didnt want to miss.
Post your pics :)
