Introduction: Pendant Lamp From Hanging Planter: Ikea Skurar Hack
I was looking for a small pendant lamp and could not find the right design. Then I came across the Ikea Skurar Hanging Planter, standing upside down on the shelves.... Exactly what i wanted and the design only needed a hole to fit in the Hemma cord set.....
Step 1: Tools and Ingredients
Tools:
marker
column-type drill
drills (I used 2mm and 3.5mm)
small metal cutter
rounded file
Ingredients:
1 Ikea Skurar Hanging Planter
1 Ikea Hemma Cord Set
1 Bulb
Step 2: First Steps...
Unscrew the plastic ring from the Hemma cord set and place it on the bottom of the Skurar hanging planter (or the top of the Skurar pendant lamp :-) ). Trace the inner circle with the marker.
Use the 2mm drill and the machine to drill small holes across the line.
Step 3: A Little Further...
Then drill again using the 3.5mm drill, widening the gaps.
Use the metal cutters to cut the last circle completly.
Step 4: Smoothhh....
Use the file to remove sharp edges and file until the Hemma cord set fits nicely.
Step 5: Finished....
Well... almost finished still need to hang the lamp and put in a bulb. But you get the idea...
