Introduction: Pikachu Rainbow Loom Bracelet
Heyo! This is my Pikachu Rainbow Loom Bracelet tutorial for all the Pokemon/Rainbow Loom lovers out there! When you have your supplies ready, move onto Step 1!
Step 1: First Ear
Place TWO Black bands on the middle peg of your loom. Then, put two yellow bands out to the left. Place two bands down on the middle and left pegs. Place two yellow bands across the gap between the bottom pegs. Hook the bands as shown in the pictures. When you are done hooking, put your hook through the black bands on the peg, and remove from the loom. Then, do a slip knot on your hook. (pictures above)
Step 2: Second Ear
Repeat the process of the first ear, except put the black bands on the left peg.
Step 3: First Row
Here is a pattern for the first row of band-placing. Take the loose bands from the ears and put them over the pegs, one space away from the end. (only ten spaces of bands per row)
Step 4: Second Row
This the pattern of bands for the second row.
Step 5: Third Row
This is the pattern guide for the third row of bands.
Step 6: Connector Bands
Place a band across the bottom pegs of the loom. Continue all the way up the loom, but stop at the top row.
Step 7: Hooking
Hook the left and right bands on the INSIDE of the connector band, and hook the middle band on the OUTSIDE of the connector band. Then, hook the rest of the bands normally, as you would a triple single. When you get to the end, take the bands on the left and right pegs and move them to the middle. Put your hook through the bands on the middle peg and remove the bands from the loom.
Step 8: Slip Knot and Extension
Do a slip knot like I showed you in Step 1. Then you take the middle of the connector band and put it on your hook. Slide it onto a band and repeat the process to make a short single extension.Then, take the loop on the right, pull it off the hook, and tighten to make a slip knot. Attach the bands on the end to a c clip.
Step 9: You're Done!
You're done with your Pikachu bracelet! I hope you enjoyed this tutorial! Feel free to request more Pokemon tutorials, I will make them A.S.A.P.!!!!! Byeeeee!
