Introduction: Quick and Easy Tazer, Make to Look Like a USB Dongle
This is a simple, quick and easy way a to make a which is is meant to look like a usb dongle. Its really easy to make.
Requirments:
Lighter
USB Dongle (Any will do, i used a broken one)
3 x screws
A Hammer
A Screwdriver
Warning!: Anything you do with this is your sole responsibility. I am not responsible for anything you do with this, or any trouble this causes you. Remember, high voltage is dangerouse, it can kill. Do not taze anybody with a pacemaker of anyother mechanic body part, or anybody with weak organs.
Step 1: Disembling the Lighter
Firstly, unscrew your lighter, the part we will be using is the small ignition system, it is designed to make electricity arc and set alite the gas that comes out of the container also in the lighter. But we wont be using it for that.
Step 2: Taking Apart the USB Dongle
Pretty straight forwould, the fixings will probably be diffrent for each type of dongle. The circuit bored you can salvage but the USB end we will need. I also knocked out the plastic parts where lights had been. There where two holes, perfect for threading the two wires through.
Step 3: Mounting the Internals
I used 3 screws, i threaded 2 through the side then layed one screw on the two screws going through, i then layed the sparking mechanism on it., ontop of the sparking button thing i layed the usb top, there was metal on the side on the usb connecter meaning it wouldent come out on the dongle
Step 4: Screw It Up and Your Finished
Screw it up and your finished. Rember be responsible with it!
