Introduction: Solar System Light in Bulb
bulb in a bulb ,solar system in a solar system just try and make it it you want some thing fantastic
Step 1: Material Required
- 200 Watt bulb
- small bulb(3 v)
- nail (5 cm)
- pliers
- wires
- thermocol balls
- screw driver
- colors
- 20 AWG copper wire
- soldering iron and wire
Step 2: Dismantle the Bulb
Hold the bulb with a firm grip and remove the metal base . The gently break the lower part and be carefully
Step 3: Securing the Bulb Edges
Secure the bulb edges by the paper mache .To make paper mache mix the news paper,glue and water and make a paste and put it on the edges
Step 4: Making Holder for Planets
Take the copper wire of about 22 cm and twist it and wrap around the bulb.
Step 5: Making Solar System
Color the thermocol balls and put them in the order of the origonal solar system.Also solder the bulb as shown
Step 6: Make a Stand
Hot glue the nail to the end of the bulb. Next gently slide the solar system in it.
Step 7: Making the Base
Make the base from the card board and punch a hole through it and pass the wires and nail and hot glue the nail to the base. Stick the base to the bulb. Stick the black paper to make it look good.
Step 8: Enjoy the Delight
Glass Challenge 2017
