Introduction: Soldering an SMT MOSFET Driver With a Hotplate
Soldering SMD components isn't as hard as you might think. In fact it's easy.
If you follow this instructables you'll soon see just what great results you can obtain at home using just a hotplate.
It's not just being able to make small circuit boards that makes SMT soldering so good it's also a nicer way to solder. All the 'hard' work is in placing the components. You then only need to reflow the solder for about 5-7 minutes and your done.
No more long soldering sessions spent hunched over a hot soldering iron breathing in all those fumes.
All you need is the PCB, some solder paste, the SMD components and a hotplate.
If you'd like a kit that includes the PCB, components and solder paste then follow this link
SMD MOSFET Driver Kit
More information is available at
www.CarbonFrog.com
Step 1: Gather All the Parts
Gather and identify all the parts, remove packaging and lay out ready to be placed on the board.
Make sure you know which resistor is which, they are each marked as shown.
Also ensure that the diode will go in the correct way round. The cathode, the end you want connected to the positive rail, is marked with a line.
Step 2: Prepare the PCB
Clean the boards' pads, preferably with isopropyl and put some flux on each of the pads. Also make sure the legs of the components are clean.
Step 3: Apply Solder Paste
Using a tooth pick put a dot of solder paste on each pad. Don’t use too much and avoid splats and bridges. Less is more with solder paste.
Step 4: Place Components
Carefully position each component (starting with the smallest) using a pair of tweezers. At this point a magnifying ring or head mounted magnifying goggles can really help.
WARNING! Make sure the diode is the correct way round and that the two resistors are in their correct positions.
Step 5: Setup Hotplate
Place the board on a hot plate and prepare for soldering. It is also a good idea to place the board on an aluminium plate if you have one. This not only makes it easier to move around, but also at the end of the reflow process you can pick up the plate with a pair of pliers and put it elsewhere to cool. Doing this will allow it to cool quicker and avoid over heating caused by thermal inertia.
Step 6: Reflow Solder
Ideally the solder paste should go through a reflow profile specific to that particular paste.
But they are all fairly similar and as long as you try to follow the profile you should get good results.
Heat to about 200ºC - 230ºC (390ºF - 450ºF) using a thermometer, try to follow the reflow profile. After a few minutes you should see the solder turn shiny and flow, you should also see a little puff of vapour. Don’t let it get too hot or peek too long as this can burn the board and damage the components.
Step 7: Check Results
You are looking for a blend into the pad and the components terminal. This is known as wetting. It should have the appearance of draped cloth. If it looks like a bead of liquid then its a bad joint.
If you do make a bad joint just put some flux on it and reheat with a soldering iron.
Step 8: Test and Hook Up to Your Arduino
Finally it's a good idea to test the board before connecting it to a microcontroller. Use a multimeter and a power supply with 12v and 5v, connect the 12V to the positive rail and take the signal to 5V.
When you're happy everything is good to go, connect it to your project. There are many possible ways to do this. Here are a few possibilities. I've also included a schematic so you can decide exactly how to use it.
I hope you enjoy SMT soldering as much as I do and if you would like one of these kits then just go to this link.
Please also check out CarbonFrog.com for more information and kits.
Hurricane Lasers Contest
