Introduction: Supercharged 9 Volt Battery!!!
Scare the crap out of your friends with this new "supercharged" 9 volt battery!! WARNING: If you have a pace maker or are dependent on any other electronic device for life support do not touch this battery!!!! also i am not responsible for ANYTHING stupid you do with this including but not limited to loss of life or loss of property due to 1 hell of a jolt!
ALSO make sure the capacitor is discharged before you go messing with it
Step 1: Parts!!!!
2 9volt batteries!
1 soldering iron w/ soldier
1 hot glue gun w/ hot glue
1 16v 3300uF capacitor
common sense
Step 2: Taking Apart the Battery.
All you have to do is bend the metal flaps on top of the battery and lift out the top part you can throw the insides and the little cardboard thingy @ the top!!!! not the bottom!
Step 3: Soldier and Make Sure the Wires Dont Touch the Sides
NOTE AND A WARNING MAKE SURE THAT WHEN YOU SOLDIER YOU SOLDIER THE + TO THE + AND THE - TO THE - or you capacitor will EXPLODE!! ok now soldier the terminals to the + and - terminals of the battery on the other side ie where you cant see them (Note:bend the wires a little because the capacitor wont fit into the battery do as I do) now be sure the wires dont touch the sides then apply hot glue to the wires! put the capacitor into the case (after you coated the wires with hot glue) then add as much hot glue as possible then cover it up and seal it with hot glue to make sure it doesnt open! Your capacitor should look like this
Step 4: FINISHED!!!!!!!
Move on to step 5 for charging! NOTE at a GLANCE this looks like a 9 volt but with closer inspection it is actually a tazer A.K.A. a "supercharged" 9 volt battery!
Step 5: CHARGING
when you charge it is also imperative that you touch the + to the + and the - to the - to avoid an explosion in your hand even though it may look like the perfect fit it should never be attempted i did this as a safety thing so you dont over charge the capacitor and cant get the battery off so you have to hold it there while it charges
to charge just apply the + to the + and the - to the - for a few seconds and let off then test it out on your cat or dog or wife or friend or husband (anyone who wont bit and or kill you if you try this on them)
Hope you enjoy this!!
