Introduction: Survival Kit
Hey this will show you what you'll need to survive in the wild.
Step 1: Tools
What tools you'll need,
1.A knife or machete
2.Rope
3.First-Aid Kit (Small)
4.Compass
5.binoculars
6.Books on Animals
7.Mirror or whistle
8.Flint
9.Knife-Sharpener Stone (or a stone that won't break after hitting metal)
10.Plastic 2-liter bottles
11.Backpack
12.Nails
13.Dental floss
14.Can tab
15.File
16.Multi tool
lets get started.
Step 2: Getting Started
First things first, build a shelter. You'll need a shelter to survive on an island, because you never know what is on it.
I recommend you build a bamboo hut in the trees, because on the ground anything can be lurking on the ground.
First, gather bamboo.Next, gather leaves or even animal skins. Then, find a good tree near water. Next, build a hammer and an axe. Then, build the hut. To do this, get your hammer and axe. Use your axe and cut the bamboo to about 3 feet and put them on a branch of the tree you chose, and build walls. Build the roof by putting some 2 ft. bamboo pieces on the walls, make them in a triangular shape, then put your leaves/animal felts on the bamboo roof. Then, make a ladder or stairs. Now your done.
Step 3: Hunting, Gathering, and Exploring
By now you'll probably starving. You'll need food. To get food, you will need an spear and Altai. An Altai is an arrow and a piece of bamboo carved to look like a canoe without an end on one end. Also you can make a bow and arrow. I prefer both, but that's my opinion. Next, weave a basket so you can pick berries. Now, go exploring so you can find good hunting spots.
Step 4: Build a Fire
Now you'll need to cook the meat. To do this you will need to build a fire. Build a fire by gathering twigs and tree branches. Next, put some twigs on the ground. Then use your knife and hit it on the flint near the twigs until it's on fire. You should keep this lighted in case a rescue helicopter comes by.
Step 5: Fishing
By now you probably want some fish. Now build a boat, just small one. To do this, get some bamboo 6ft. long. Then, use rope to tie them together. Use a piece of bamboo for a paddle.
Now for the rod. To make the rod, get a 4ft. long piece of bamboo. Then tie some dental floss to it, make the piece of dental floss about 16-20ft. Next, get the can tab and multi tool. Get the pliers out and cut a hole in the tab and file it. Then tie the can tab to the piece of dental floss.
Step 6: Cliff Hanging
You might find a cliff on your island. First, find a strong tree nearby and tie a bowline knot around it. Then, make a harness with the rope and you're ready to go.
Step 7: First-Aid
Now First-Aid is not easy, so you'll need to be prepared. In your First-Aid kit make sure you pack, bandage cloth, a small bottle of peroxide, sewing nettles, thread, cast material, and pliers.
Step 8: Farming
Now I recommend the you should start farming. To farm, you'll need to make a field. To do this, you'll need a plow. To make this, you'll need your knife/machete, some wood, and dental floss. First, tie your knife to a 3ft. log. Then, tie two foot long logs to it, and your done.
Step 9: Escaping
Escaping. You'll need to escape at some time. If you do it at the wrong time, they won't see you. To escape, you'll need a whistle or mirror to attract them.
Step 10: You're Ready
You can survive on an island. Have fun!
