Introduction: The Only Postcard in the World
This is an ordinary milk corton.You may think this is a piece of trash. We can't use tricks and magics, but we can change a mere milk corton to the only postcard by going through some easy processes. Here, I will tell you that the method of making the postcard from it.
Step 1: Materials and Tools
・mixer
・scissors
・tray
・towel
・water
・empty milk cortons
・paper making set
・iron
・iron board
Step 2: The Treatment Method of Milk Cortons
Firstly, wash inside of milk cortons and cut open them on the line. Next, soak them in the tray which is filled with lukewarm water.
Step 3: The Processing of Milk Cortons
They are consisted of three layers. Concretely, both side of them have polyethylene coating, so you need to take out the middle layer. After you remove both side, you tear them into pieces.
Step 4: Using Mixer
Next, once you put water and teared up paper in the mixer, you mix them until they become thick soup.
Step 5: Making a Postcard
When you run water into a tray, you pour thick soup into a tray. Next, put it into a paper making set. After that, put a paper making set on surface and remove it.
Step 6: Dry a Postcard
You should dry postcard by using towel and iron.
Step 7: The Only Postcard
That's all, finish a postcard!
We can easily manufacture postcard by reusing milk cartons. Doing that is also friendly environment. In addition, these days, we hardly write letters or postcard in the world, you will have the opportunity to write letters and postcards. why don't you make a postcard and send it to your precious persons?
Before and After Contest 2017
