Introduction: Turn Your Baby Bottle Pop Into a REAL Bottle!
This simple hack will convert your little baby bottle pop candy into a REAL bottle for your child during road trips and long periods of time away from home. It works great, and is very simple to make!
Step 1: Materials
You will need:
{Knife}
{2 Baby Bottle Pop candies}
{Source of Water}
{Paper Towels}
{Glue}
{Tape}
{Time}
Step 2: Preparing the Bottles
To prepare the bottle for the next step, run the candy on the top under hot water (unless you ate it already :3). Then, take the knife and wedge it under the candy. With the hot water to lubricate it, it will slide right off.
Step 3: Slicey, Slicey!
Take the knife and slice off the top and bottom pegs. Then, poke a hole in the middle of the now flat top. Twist the knife to create a larger hole.You are done with this part. Set it aside. Take the clear plastic (the top) and poke another hole in the top, then twist until the hole is about 2mm in diameter. ONLY DO THIS TO ONE OF THE BOTTOM PARTS!!!!
Step 4: Glue N' Tape!
Apply glue on the outside of the ring (the one on the bottom) and insert it into the plastic 'nipple' of the bottle. Apply tape over the glue so it doesn't poison the formula/juice/whatever you put inside. Do this on both nipples.
Step 5: Assembly!
This is, without question, the simplest step. Put the drink inside the bottle and screw on the nipple without the hole. Keep the one with the hole. When your child needs it, remove the holeless top and replace it with the one with the hole. You're done!
