Introduction: Wire Wrapped Swarovski Cube Earrings
These are some simple but cute swarovski cube earrings. Total time to make these is 10 minutes, and materials and tools are easy to come by. Stop by and say hi if you like this Instructables tutorial!
Step 1: Materials You'll Need
-Pliers: round nose, chain nose, bent nose
-Wire cutters
-2 headpins
-2 6mm spacers
-2 8mm squaredelles
-2 8mm Swarovski cubes
Step 2: Stringing
String the cube, squaredelle and spacer.
Step 3: First Bend
Grip with the roundnose pliers and bend the wire down at 45 degrees.
Step 4: Second Bend
Reposition the round nose pliers and bend around and down the other way.
Step 5: Full Bend
Continue to bend the wire under the pliers, until you have a full loop.
Step 6: Wrap
Grip the loop with your chain nose pliers, and wrap the wire with your bent nose pliers until the whole vertical headpin area is covered.
Step 7: Clip
Clip the excess wire with your wire cutters, then squeeze the rest of the wire underneath the twist you just made.
Step 8: Leverback
Twist open the leverback ring, and put the loop in. Then twist the ring closed. You finished the first earring! Now just repeat these steps to complete your pair! Thanks for reading, this instructable was inspired by the Enreverie blog.
Jewelry Contest
Homemade Gifts Contest 2015
