Introduction: Wooden Air Ship Necklace
A great gift for your steampunk enthusiast friends! I made this one for a friend of mine.
Materials
Wood (The wood I used was a 1/4" and was a bit thick. I'd recommend 1/8".)
Chain
Watercolor
Paintbrush
Propeller (I used a metal flower from the scrapbooking section of the local craft store.)
Wooden Button (or other detail item for the center of the balloon.)
Saw
Jump rings
Pliers
Drill
Small drill bit
Pointed grinding or sanding bit
Hole cutting bit (I used a 1.25" diameter bit)
Glue
Step 1: Draw and Cut
First, draw out your design. You can also use mine. If you print the second image on a full sheet of paper, you can use it for a template.
Cut out the ship section from the drawing and trace it onto your wood.
Cut out your wood piece.
Use your hole cutting bit to cut out the balloon.
Step 2: Drill and Sand
Again, use the template to mark and drill holes in the two wood pieces.
Sand them smooth.
Use the grinding bit to sand the holes and create portholes in the ship piece.
Step 3: Paint and Add Details
Use watercolors to paint your wood.
Glue the button onto the balloon piece and attach the propeller.
Step 4: Add Chains
Add jump rings to all the holes and chain the two pieces together.
Step 5: Enoy
You're done! Go out on the town or gift it to a friend!
If I won a Form 1+ 3D Printer in the Formlabs Contest...
I would be able to create and print new parts for other projects instead of fabricating them like I did with this one. Projects like this would be even more reproducible if I could provide the file for the pieces I made. Being a public school teacher, I would love to have the opportunity to print some of my student's creations. Each student has an iPad with various 123D apps on them, and I've always wanted to experiment with creating collectible art toys.
Homemade Gifts Contest
Wood Contest
Formlabs Contest
