Introduction: A Simple Utilitarian Mop
Step 1: Things You Will Need
1. a rag
2. a piece of string
3. a length of pipe (i used on this particular one brass because it wont rust)
4. a pair of scissors or a knife
optional: a pipe cap.
Step 2: Assembly Starts
first take your rag and twist it like u would if u where wringing it out. then place the bit of string looped around the center.
Step 3: ......
now take both ends of the string and feed them through the pipe.
Step 4: ......
now give the 2 ends a good pull and draw the rag up into the pipe tightly. leav a small amount of room rear the end of the pipe so u can coil the string down into the pipe before putting the pipe cap on if your using one, this will be usefull later if your comes aloose.
Step 5: Finishing Up
now trim the rag according to your needs and coil the string up like i mentioned before and screw the cap on
