12vdc to 5.how to convert ?
i have one supply unit at 12 volts and i want to get 5 volts also. i need resistance or voltage regulator like lm317?
Re-design8 years ago
Regulator. LM 7805. Best option.
+1.
luxstar5 years ago
Here is an instructable using a DC to Dc converter:
https://www.instructables.com/id/93-efficient-DC-to-DC-Converter/
The data sheet says the input voltage can be 4.5 to 14 volts. The output can be adjusted from one half volt to 6 volts. Murata makes several different devices for different current / wattage requirements;
http://www.futureelectronics.com/en/Search.aspx?dsNav=Ntk:PlainTextSearch%7coktr%7c3%7c,Ny:True,Nea:True
frollard8 years ago
a linear regulator is the cheapest option - not the most efficient - there are digital switching supplies that bump the voltage up or down (boost or buck) at near 95% efficiency, where the lm7805 burns off more than half the energy to drop the voltage down to the required level. Just a thought.
napoleonis (author) 8 years ago
thanks a lot :D
led2358 years ago
5v regulator! wot woot
