3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
1/4 inch mono audio jack question. REAL simple?
I am building http://www.montagar.com/~patj/fuzz002.gif
 I am using a 1/4 inch mono audio jack like this one http://www.maplin.co.uk/images/Full/hf90x&fj00a.jpg
I know the output on the lft is negative while the one on the right is positive.
my question is on the circuit the jack on the far right only has one wire leading to it. it it positive or negative.
Jun 26, 2010. 2:47 PMRe-design says:
They answer it "neither". It's and audio signal.
The "output" as you call it on the left is actually the input.  It has a connection to the neg. terminal of the battery because it is also the on/off switch.  When you plug in a mono jack to this stereo socket you are shorting the neg terminal to ground turning everything on.
Jun 27, 2010. 6:01 AMRe-design says:
That jack has two connections.  But they are both output.
One is the ring and the other is the tip.
The ring connects to the ground (which is the ring on the input and the only other ground connection).
The tip connects to the wire going to d1 and d2.
Jun 26, 2010. 2:10 PMlemonie says:
Your "out" is the signal, it's relative to GND, so it's +ve. Tie the other connection to -ve/GND.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
