1MΩ Voltage controlled resistor?
Is there any good way to hook up a fairly wide range voltage controlled resistor circuit? So far, I've considered FETs and OTAs. I only have chopper FETs on hand and the datasheet does not list the Pinchoff Voltage. The OTA resistor setup still seems confusing to me.
These will be used in a Voltage Controlled Oscillator circuit.
Any ideas? Am I on the right track?
The FETs a classic, and simple method. Just use a standard Jfet. This is one of the best references I know. http://www.qsl.net/n4xy/PDFs/Semiconductor_Application_Notes/Vishay-Silcnx_FET_VoltCntrlRES_AN105.pdf
You COULD mung somehting from an LDR and an LED as well
Steve
