3v leds x 20, leds paralel, 3v in, led calc says use 1 ohm each resistor, can I skip that since 3v led and 3v input v?
3v leds x 20, leds parallel, 3v in, led calc says use 1 ohm each resistor, can I skip that since 3v led and 3v input v?
Led calc also says 0 ohm / use the next standard resistor 1ohm..
does 1 ohm x 20 really needed for a 3.0- 3.2v white led with a 3v 2000ma source>
thanks in advance..
6
answers
Answer it!
If your power supply is 3V and they are 3V LED's then you do not need any resistor.
I don't see why anyone thinks a 1ohm resistor would suppress anything?
Dynamic resistance of the LED when operating at full intensity is something like 150ohms.
(3V/0.02A)
If the supply voltage would raise 1V, with no resistor, you'll get 4V over your LED, killing it instantly.
If the supply voltage raises 1V, with a 1ohm resistor, you'll get 3.97V over the LED and 26.49mV over the 1ohm resistor.
3.97V over the LED would still kill it.
Now it doesn't really look like a 1ohm resistor would 'protect' your LED right?
If you're using a 3V supply, I'll guess you're on AAs?
Bump it up to 9V at least, run some in series.
It's easy to double-up 9V batteries to 18V - so you might run 5 in series with a resistor, 4 times.
L
