loading
3w led with two D cells.
The led is 3,8V drop 800mah, and the bateries are only 2,4-3v, there is any simple circuit to make it work properly? Maybe a joule thief, but i don't know if i can pull 800mah from it. Any sugestions? thanks.?
frollard4 years ago
3.8v@800mA is a stretch for 2 d-cell batteries. Up it to 3 batteries, because any boost converter you find is going to have a problem with 3 watts from 3 volts.
notingkool (author)  frollard4 years ago
there are already boost that draw 1w from a single AA cell. why not 3w from two D cells?
*that said
this is the closest I can find in a flashlight driver variant. Only puts out 700-800mA on 1.5-3v input.
http://www.dealextreme.com/p/700-800ma-3-mode-regulated-led-driver-circuit-board-for-diy-flashlight-3v-pair-128086?item=18
The 1AA 1W boosts are usually not actually putting out the full watt -- I have a 1w led flashlight that runs on a AA or lithium equivalent size - and the 3.7v to 4v boost is doable, the AA mode is significantly dimmer.
