loading
4 wires fan to 2 wire
Hi guys, i need your help!
I have an Enermax 12cm fan (EB122512H), i need to plug it to a 12v DC power supply but i don't know how to wire it;
The fan has 4 wires (yellow, black, white, red) but the power supply has just two wires.
could you help me?
Picture of 4 wires fan to 2 wire
Jarnsaxa10 months ago
Google brought me here. I found the same fan in some old broken PSU. Did not work at first, but don't give up yet fellows :-)
Yellow +12V
Black GND
White rotation sensor
Red PWM input
Since this product is not meant to be replaced with standard components, Enermax omitted the pull-up resistor on the PWM input. Simply connect Yellow and Red to +12V and the fan will run.
MichelS7 (author) 1 year ago
i have tried all the possible configurations but it doesn't work :\ when i try black and red the fan moves a bit for a tiny instant but it stops immediately.... i think it is broken because it starts to stink like a burnt circuit
That smell might be the smell of magic smoke,
https://en.wikipedia.org/wiki/Magic_smoke
There's not much the Answers forum can do for you if your fan has released its magic smoke. ;-)
If this is the case, I am hopeful you will find another fan, and hook that one up correctly next time.
Here is a project idea for broken PC fan. Assuming the windings and magnets are still good, you can make a very tiny alternator generator.
https://www.instructables.com/id/Old-PC-Fan-Wind-Tu...
That is, if you can take the fan apart without breaking it, and also manage to rewire, de-solder, re-solder, the stuff connected to the fan's windings.
MichelS7 (author)  Jack A Lopez1 year ago
thanks =)
I think that might be a PWM fan, and this page,
http://www.pavouk.org/hw/fan/en_fan4wire.html
sort of explains the pinouts for this kind of fan. The four wires are: ground, +12V, PWM input, and speed sense output.
I think if you can figure out which two wires are ground and +12V, and leave the other wires open, i.e. not connected, then the fan will turn at full speed.
If I had bothered reading the comments I woudl ahve seens yours and moved on
+1
seandogue1 year ago
Can't sake with 100% assurance, but see
http://www.kitguru.net/components/power-supplies/z...
For an interesting tidbit.
"The 120mm Enermax branded fan (EB122512H) is controlled to rotate between 450 rpm and 2,000 rpm depending on the ambient temperatures. It is a 9 blade design and incorporates dual ball bearing and is rated for 0.30A at 12V."
It could be the two extra wires are for measuring fan speed (my fav) controlling speed, or it could be a stepper (although that seems overkill for a power supply fan)
sure enough...a quick search of google images for Enermax EB122512H presents this "insitu" image, which answers it handily:
iceng1 year ago
Use +red and -black.
Yellow on +12V
Black on Ground
I suspect the other two are for spped control/light.
MichelS7 (author)  Downunder35m1 year ago
if i just use the yellow and the black, the fan doesn't run... is it possible to bypass the speed control?
Hmmm, unusal but try red and black.
Would mean Yellow is used for the speed sensing.
+1
