555 timer - 1200hz square wave generator?
Thank you.
8
answers
Answer it!
Here is a good tutorial site that will help you calculate the approx. frequency. If you need it exactly 1200 then you will have to check it with a freq. meter.
What a person could use is a 32.whatever khz clock crystal - and a binary counter (frequency divider) - and an 8-input 1 output and gate to say "if all these bits of time are set, then it's been 1/1200th of a second; lastly a flipflop that is configured to pulse-on-pulse-off to make the full square wave.
As for the precision needed, I am currently looking at Xander Soldaat's driver to see if I can read a "general" IR signal, not limiting me to the 600hz or 1200hz that the sensor setup uses. I know for a fact that a tv remote does work with the IR Seeker (as according to the robotc "NXT Devices" menu (allowing me to view sensor and motor rotation data). It is just an API question then which I will solve when I have a minute.
If you have the battery in the circuit and it receives more power than it has, then it will charge until full. It should charge so long as more power is provided to the entire circuit than is being used by the rest of the circuit. If you have a trickle source, why not just run the circuit off that source?
Today I was able to successfully breadboard an astable 555 emitting a ~600hz square wave - driving an IR led. (RobotC provides support for the 1200hz signal and a 600hz also. The perfboard design of this is in the works, to be completed within another day or so.
So I need a small trickle charger circuit. I have some DC Jacks so maybe if I could do the power input from a wall-wart when charging...
Also I have seen some other similar threads in questions here so I might make an instructable about producing this...
Thanks for all of your help (frollard and Re-design), and again please help with the smallest possible trickle charger. I will look around at some instructables to see what I can come up with.
