loading
5V Power bus?
hi, where the 5V power bus red wire linked to the LED ?
bekathwia2 months ago
It's not, you'll use it next lesson. From the text:
"This is a common configuration you will use again and again, and should be your go-to setup for new breadboards, even if you aren't using both buses immediately. Circuits in this lesson will connect to the ground bus, and in the next lesson you'll use some components that will connect to the 5V power bus."
