3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
6 volt LED lantern joule thief
I'm about to embark on a project to build a joule thief to power my new 6 volt LED lantern. I'm going to replace the lantern battery with the same volume of half dead AA batteries, which I have a bowl-full. My mice and cameras reject the AAs when they are only half done. The joule thief should finish them off.
My question is if I might be just as well off to wire my AA four battery packs in a series/parallel circuit. First start parallel, then series as the batteries run down. This would give me a high/low control for the light, too.
The joule thief will only draw the batteries down so far, and the LEDs have a low voltage threshold. Since the light is engineered for six volts, I'm just wondering which way to go.
Oct 19, 2011. 10:35 PMiceng says:
A jewel thief as I believe they work are meant to use an inductive component
and trans form a low voltage from a single battery to a  higher voltage to
light an LED that the battery alone could not.
Jewel thiefs come in many configurations.  This one is is more complex and runs a battery down to 0.7VDC.
I provide the circuit, the PDF of the IC and the pointer to the instructable.
Hope this is a learning experience 4U. . . . . . .   A
Oct 23, 2011. 11:46 AMacmefixer says:
I wonder what purpose the 100 ohm resistor is for? It seems just a waste of power that would otherwise go to the LED. Also I wonder if the chip has a way to sense the current so the current through the LED could be constant. Obviously I haven't checked out the datasheet for this chip yet. I've checked other Maxim chips and found that they seldom have a DIP version, most are tiny SMD which makes it really difficult to experiment with. That's another reason why most experimenters stick to the Real JT, with a single transistor.
Oct 23, 2011. 2:35 PMiceng says:
This is a much more efficient jewel thief able to start as low as 0.7V.
In fact you can run it off of two cells in series 3Vand run that down to
0.7V which means you can suck each cell down to 0.35VDC.
The MAX1675 is a constant voltage output device and a series resistor is
necessary unless the LED is designed to use ½ Amp.  Another reason for
the 100 ohm resistor is to make it easy for a scope current measurement.
IF you have a look at this ible where it says in step one,
That "Sorry, but this project requires advanced soldering skill to build !".
Yes, there are many easy JT projects for beginners.
This JT project however gives advanced users a chance to strut their stuff,
and besides the very detailed learning instructions the ible allows the user
to make a very tiny unit.
A
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
