loading
6.3 Jack To 3.5 mini jack how?
Hello everyone, sorry for the trivial question..
Is possible to cut the wire and manually connect a 6.3 with a 3.5?
tutdude983 years ago
Just conect same tips
Biggest one is ground then its right and tip is left
Use a meter and do a continuity check to see what wire is connected to which part of the connector. Then you can match the wires of the connectors up.
Yes, its simple. You'll need to solder the connections though
