A/C-Broke for Aerostar. Need ideas for simple/inexpensive roof replacement?
plug in small room A/C or roof venting unit? Buy used would keep costs down. Watcha think?
goguddy
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
I thought somebody might have a source of units, etc..
Thanx, goguddy.,
As far as disconnecting the rear unit you should be able to do that with no problem. There should be somewhere that branches off of the main system. If it has a connector with a seal, you can disconnect it then cut the tubing and solder it closed and reconnect it to the system as a plug. This way you avoid heating up the seals which you might do if you try and solder it in place.
