3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
ATTENTION ENGINEERS: Inductor to limit inrush when starting an electric motor?
The situation: I am using a contactor (like a big switch) to start a brushed permanent magnet DC motor. I am not using a motor controller. The motor is a Mars 0909 which draws 4.8 KW continuous and 15KW for 30 seconds
The problem: This current can cause arcing at the contactor which can erode the contactor's electrical contact points and perhaps stress the batteries or blow a fuse needlessly.
The goal: Reduce inrush while the motor starts up.
The question: My teacher suggested I use a large inductor in series with the contactor. Theoretically the inductor would resist the initial inrush of current and then its resistance would go way down. We looked around a bit and didn't find any motors in series with an inductor in series. Is there a reason why inductors an not typically in series with motors?
Is this something like a "Peterson coil" or an "arc suppression coil"?
Any idea what the formula would be to calculate the size of such a coil?
Jun 8, 2011. 9:50 AMsteveastrouk says:
Run the math, and size the inductor needed.
You should be using a motor starting contactor rated for the load, probably with magnetic arc breakers.
Unless you have active control big DC motor= big starting surge.
Steve
Jun 9, 2011. 12:36 AMsteveastrouk says:
Also, big motors like that can ramp to speed VERY VERY fast. Make sure the motor is bolted to a strong suport, or it WILL bounce down the workshop
Steve
Jun 8, 2011. 12:51 PMiceng says:
Your very correct Steve, we called them magnetic starters some automatic
some manual.  They would limit motor inrush current in several steps and
were designed to Quench DC arcs.
I still have a Repulsion Start, Induction Run power planer motor.   Alex
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
