About audio amplifier boards?
I've brought TDA2030 amp board for stereo system(pictures attached). I can't identify audio input terminals. Experts please help me!
Picture of About audio amplifier boards?
iceng1 year ago
Red=positive 12volts DC and Black=negative ground supply power for the amplifier.
Yellow and Black pair each are a pair of speaker wires.
Just before the negative of the 2.2 uF negative there appears to be an input where you could solder a Green-signal wire with a gray wire for ground times two.
A better straifght cook down at the pcb would help trace the inputs.
chrisjlionel (author)  iceng1 year ago
Thanks. That really helps. pin 1 followed by caps + terminal is signal input.
Correct !
chrisjlionel (author)  chrisjlionel1 year ago
**caps -ve right
rickharris1 year ago
http://www.st.com/web/en/resource/technical/docume...
shows inputs to be on Pin 1 of the IC. You will need a 20k pot as shown to provide volume control/ballance.
chrisjlionel (author)  rickharris1 year ago
Thanks for helping.
Ask where you bought it, if they can't provide the info hand the junk back and get a refund.
chrisjlionel (author)  Downunder35m1 year ago
That's the problem. No refund for goods imported from china. Clearly stated in the bill.
